Lifting an OBS to fit 40's.
This is my first post. I searched the web and this website and couldn't exactly get what I'm looking for. I'm looking to lift the truck on 40 inch tires. I was thinkin 10 inches of lift and I'd prefer suspension lift and stay away from body lift. Where could I get a suspension lift of 10 inches. But the biggest I can find is 8 inches from skyjacker. Do you guys have any advice?
You can lift a leaf spring suspension pretty easily. But when you start getting fairly high, things get complicated. Too much angle on the drag link is a prob. You get bump steer and bind as the suspension compresses. To level the drag link, you need to move it from the tierod to the top of the pass side knuckle. Here's a kit: ORU Crossover Steering Conversion Kit for 8" - 13" of Suspension Lift Late 1999-2004 Ford F250/F350 with a Dana 50/60 Axle - Crossover steering Dana 60 and 50 - Off Road Unlimited
If you use an older "king pin" d60, the crossover conversion is MUCH cheaper to do.
Are you against cutting out the fenders for tire clearance? You can fit alot of tire with much less lift that way.
I also didn't mention problems with the panhard bar because I feel it's not necessary to have one. My truck below hasn't had one for about 30,000 miles.
A Dana 50 solid is a super duty axle and has a different wheel bolt circle 8x170mm if I recall.
Look at bushwacker cutout flairs. Clean look and clearance for larger tire. You'll need at least 8" of lift plus some trimming. 9 or 10" would be better, but the front bumper will need to be trimmed pretty good.
Get the tires, measure the stock height of the truck, then jack it up for the bigger tires and measure the height again and there's how much lift you'll need. Do the SAS with a stock set of springs and go from there. An RSK is a good idea as it'll lower the spring mounts so you don't need as much arch.
Jason185512
02-20-2017 07:19 AM
Gregorri
06-01-2005 12:18 AM
