Access to OEM Horns & Wires
#47
Your video settings are set to not allow playback on other places
than Youtube. You can copy the URL and watch it at Youtube.
Anyway nice job.
Sean
6.0L Tech Folder
Anyway nice job.
Sean
6.0L Tech Folder
#48
I recently installed horns tonight on my 2011 f250 I cut the positive factory horn wire at the horn, then ran the 12v source to the (off) position of an on-off-on switch and had one wire from the switch run back to factory horns and the other wire run to air solenoid. But now the factory horn just clunks no sound but when switched to the air solenoid it will actuate, and when I double tap the key fob it will not actuate the solenoid when that position is selected on the switch. Does anyone have experience with this issue? Does it have to do with relay/module of the truck?
bagman1995
13
10-28-2023 04:28 PM
PowerstrokeJunkie
13
06-22-2007 12:34 AM
