78 f150 floor
Old 12-10-2014, 02:30 PM
rebelson88's Avatar
rebelson88
rebelson88 is offline
78 f150 floor
Trying to replace my rubber floor in my 78 f150 regular cab 4x4 4speed. How do you find out if you have the large hump or small hump? I don't wanta guess and buy the wrong one.
Old 12-10-2014, 02:46 PM
hickory1991's Avatar
hickory1991
hickory1991 is offline
Pretty sure 4-spd is the large hump. At least my F-250 4-spd is a large hump.
Old 12-10-2014, 03:02 PM
rebelson88's Avatar
rebelson88
I'm not sure if 150 and 250 would be the same
Old 12-10-2014, 03:31 PM
hickory1991
I think there is a difference between 2wd and 4wd, but since both are 4wd I am thinking high hump.
Old 12-10-2014, 06:11 PM
rebelson88's Avatar
rebelson88
Idk I have read that all 4x4 are high hump and I've read they're not idk what to believe
Old 12-10-2014, 06:32 PM
hickory1991
Maybe this whttp://www.stockinteriors.com/items.asp?MakeId=34&ModelId=210&MainCatId=5&Desc=F ord_Full_Size_Truck,_Standard_Cab_Rubber_and_Vinyl _Flooringill help.
Old 12-10-2014, 06:35 PM
hickory1991
Old 12-10-2014, 06:44 PM
4x4slik's Avatar
4x4slik
4x4slik is offline
so, if I read that correctly, if you have some sort of shifter coming out of the floor, it is a high tunnel. If not, low tunnel
Old 12-10-2014, 06:52 PM
hickory1991
2wd standard trans or 4wd high tunnel.
Old 12-10-2014, 06:55 PM
rebelson88's Avatar
rebelson88
That's what it looks like for the 2wd mines 4x4 on that site I'd be looking at either 5570 or 5571
Old 12-10-2014, 07:06 PM
hickory1991
5571 since you have 4wd and 4spd.
Old 12-10-2014, 07:23 PM
rebelson88's Avatar
rebelson88
Yeah its gotta be the high hump. Just from comparing the pictures I could tell. The small hump is just a straight hump while the large one goes up back in and the up again. Looks exactly like mine. Thanks guys
Old 12-10-2014, 07:27 PM
hickory1991
Glad we got it figured out.
Old 12-10-2014, 07:31 PM
rebelson88's Avatar
rebelson88
Me too now just gotta order it
Old 12-11-2014, 09:16 AM
Drac's Avatar
Drac
Drac is offline
Save the old ones
Isn't it as simple as the high hump has the removable trans/floor pan cover and the low hump does not have the removable cover?
I don't think there is a difference in the steel floor stamping. Is There?
Maybe I'm wrong, ( it happens), But I thought the standard floor is the same for all the trucks, but when there is a floor shifter or 4wd, ford cut out a large (10'x18") hole in the hump and added a floor pan cover. which is 2-3' taller thus causing a high hump.
OR am I wrong and there are two different floor stampings?
Quick Reply: 78 f150 floor
