Trying to replace my rubber floor in my 78 f150 regular cab 4x4 4speed. How do you find out if you have the large hump or small hump? I don't wanta guess and buy the wrong one.
Pretty sure 4-spd is the large hump. At least my F-250 4-spd is a large hump.
Yeah its gotta be the high hump. Just from comparing the pictures I could tell. The small hump is just a straight hump while the large one goes up back in and the up again. Looks exactly like mine. Thanks guys
Isn't it as simple as the high hump has the removable trans/floor pan cover and the low hump does not have the removable cover?
I don't think there is a difference in the steel floor stamping. Is There?
Maybe I'm wrong, ( it happens), But I thought the standard floor is the same for all the trucks, but when there is a floor shifter or 4wd, ford cut out a large (10'x18") hole in the hump and added a floor pan cover. which is 2-3' taller thus causing a high hump.
OR am I wrong and there are two different floor stampings?
