292 manual to auto trans///how hard?
I am pondering rebuilding my 292 with manual transmission, floor shifter. I am beginning to believe that before the rebuild is complete I will at the very least have neuropathy and who knows what else to prevent me from driving a manual trans. Thinking of upgrading to an automatic trans. Any thoughts?
Are you thinking about a auto that bolts directly to the y block or one that bolts with an adaptor?
Neither will be cheap.
The 64 AT cooled through the engine block, not the radiator like the 65+ trucks do.
Unless you find a donor vehicle with everything intact, Im guessing that you will hunt for parts for years to do a period correct conversion.
If you can swap the engine and transmission, then you should have no problem swapping only a transmission as an entire swap will not be easier.
Your options are many. The easiest is to find an original truck auto, as shadowrider stated. That should be easiest to install, but hardest to find. Next is to use a car transmission and make mounts for it. That will be much easier to find but harder to install. Next is to get an adapter and use almost any transmission you want. This is also easy to find but possibly slightly harder to install than the Y-Block car option
If you have not already, get a shop manual for the truck. Read through everything about the manual transmission in the truck, the automatic transmission installation and removal, steering column installation and removal, and that will give you a great idea about what is involved.
Any other aftermarket conversion will be more or less the same with the exception that you will have to devise some way to mount the transmission to the truck since the mounting ears will no longer be on the bellhousing. There may be other small things involved but if you get to the point where you are comfortable with making mounts, then they should be no issue.
Ford-Y-Blocks.com has a bell and flex plate kit to adapt the C4 to the y block. It even has a starter drive gear, so you can use the more modern FE type starter. It looks to be a fairly straight-forward swap. This kit is around $550. Summit has a C4 for about $1200. This is cheaper than the T5 conversion; and, probably easier. I'm very interested to see if anyone has tried this conversion. I've got to decide if this is for me in the next several weeks. That yellow 63 Unibody would really drive a lot better with an automatic as opposed to the granny gear 4 speed!
Jaydog615
12-07-2014 06:03 AM
MERCMX
08-19-2014 07:35 AM
Fordman96
09-04-2011 05:50 PM
