1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Swap 6.8 in F350 6.4
Old 12-10-2014, 04:11 AM
fahad_h's Avatar
fahad_h
fahad_h is offline
Hello
What do I need to swap a V10 6.8 3V in a 2009 F350 6.4L?
truck in Saudi Arabia, and the diesel engine failed because of very bad diesel grade in the country.
any help is appreciated.
Thank you
Old 12-10-2014, 05:19 AM
senix's Avatar
senix
senix is offline
Received 1,398 Likes on 995 Posts
right off the top of my head you will probably need to rework the motor mounts.
new bell housing and torque converter.
New PCM from the donor truck as well.
Do you have the donor truck? maybe it is good enough to just fix that up and drive it?
Old 12-10-2014, 03:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
You can't replace the bellhousing. It is a one piece case. And you don't need to, the 6.8L and 6.4L have the same bolt pattern. The trans will work, but you will need to replace the torque converter with a converter for a 6.8L or it will drive terribly.
Old 12-10-2014, 03:27 PM
senix's Avatar
senix
senix is offline
Good know, thanks. What about programing though? Will the TCM need updating?
Old 12-10-2014, 09:06 PM
Irelands child's Avatar
Irelands child
Irelands child is offline
The best way is to find a similar year gas truck that was wrecked and swap in everything that is gasoline engine related to the diesel truck. You will need the gas tank with the correct feed and return lines and the V10 exhaust system along with all of the electronics under the dash as well as under the hood for ease of swap over. You may also want some lighter front springs too as the V10 does weigh less. Lots of work!!
Old 12-11-2014, 12:27 PM
Mark Kovalsky
Yes it will. The diesel software will shift the trans at too low of an RPM for a gas engine.
Suzuki357
Modular V10 (6.8l)
02-06-2018 07:28 AM
ramclain
03-17-2014 02:26 PM
symonds86
05-03-2010 09:18 PM
jdap
04-23-2010 06:58 AM
sandaholics
08-06-2008 02:11 AM
Quick Reply: Swap 6.8 in F350 6.4
