6.2L V8 Discuss the 6.2L V8
I need honest opinions about the 6.2
Old 07-09-2017, 08:07 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Thanks, learned something new today. Didn't realize the 265's are an option.
  #62
Old 07-09-2017, 08:16 PM
Addison86's Avatar
Addison86
Addison86 is offline
Originally Posted by Ron94150
265's? Are they stock tires? I thought 245/75 was the only option for 17" wheels. What kind of mileage did you average and what kind of terrain?
Also, check your speedo with gps, my speedo was a few mph slow with the stock 245/75r17's. I bet you will be right at 2150rpm if you go by gps 70mph.
1980 rpm would be if you had factory 20" tires.
So he says 2100 rpm, you say more like 2150.. Don't you think that's splitting hairs a little? Lol.
And I'll say mine is about 2100 rpm @ 70 too.
  #63
Old 07-10-2017, 04:14 AM
DCP's Avatar
DCP
DCP is offline
Originally Posted by dnewton3
You can either get factory 245/75-17 or 265/70-17. Both have essentially the same tire circumference; close enough that the speedo does not have to be changed.
The diameter of the 245/75 is 31.5", whereas the 265/70 is31.6". That is only a .3% difference. Not 3%, but 0.3%. In essence, in a mile of travel, the smaller tire will only go around 2 more revolutions in the entire mile.
Your tires will see more change in the wear over their lifetime than that of the two choices above.
Yes, a lot of people think that the first number is the height of the tire, when it's actually the width of the tire in millimeters. You have to account for aspect ratio when determining the tire's height.
  #64
Old 07-10-2017, 04:27 AM
DCP's Avatar
DCP
DCP is offline
Originally Posted by ATC Crazy
Those of you with 4.30's and stock tires...what RPM's are you running at 70-75mph, empty, on the highway?
I'm 98% certain I want 4.30's. I rarely drive more than a few miles on the interstate a year...but the occasional 1,000mi round trip to NY is not out of the question. 95% of my driving is 35-55mph roads here in the Appalachian mountains. I also have a 10k equipment trailer I tow about once a month or so.
With the six speed transmission, the 4.30 gearing works well at any speed. IMO, 6.2L trucks should come standard with 4.30s. Stating the obvious, gas motors don't produce the torque of a diesel, so gas motors needs all the mechanical advantages that they can get via, lower gears. I run the stock 245/75/17 tires.
  #65
Old 07-10-2017, 06:16 AM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Originally Posted by Addison86
............Don't you think that's splitting hairs...,,,,.
Not really, there is less than a 300 rpm difference between 3.73's and 4.30's(don't confuse that little number with a nearly 15% increase in torque leverage). So 50 rpm is a large percentage of that, and also right at 5mph.
I'm using an rpm calculator that uses math to get an exact number, not trying to judge off a large tach with no reference lines.
  #66
Old 07-10-2017, 06:20 AM
Addison86's Avatar
Addison86
But in real life, where most of us spend our time, 50 rpm doesn't matter. "Oh snap! I'm at 2150! I better back it down so I'm at 2100.."
  #67
Old 07-10-2017, 06:22 AM
Ron94150's Avatar
Ron94150
Ron94150 is offline
When I was 17, and knew it all, I was at a local tire/lube/exhaust shop. I new the owner pretty well, and he was getting up in age. I was getting some exhaust work done on my mustang, and was talking to one of the younger workers about getting some wider tires. As we talked, we began to disagree about which number was width and height. When the owner came by, and heard us, he said, "your both right, and neither one of you know what the hell your talking about".
  #68
Old 07-10-2017, 06:32 AM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Lol, ok, ok. Your right about that. I was just giving to best answer I could to a question that was asked. The point is, with a double overdrive, even with the small tires, it's not bad at all even on the interstate.
  #69
Old 07-10-2017, 12:21 PM
DCP's Avatar
DCP
DCP is offline
In this age of the internet, it's arrogant to be ignorant.
  #70
Old 07-10-2017, 10:13 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
This was well before the age of these forums and smart phones.
  #71
Old 07-11-2017, 12:40 AM
RainDesert's Avatar
RainDesert
RainDesert is online now
You will be much better served with the 4.30's. I get great mileage under 70 mph, just like the diesels and 3.73 trucks.
  #72
Old 07-11-2017, 12:42 AM
RainDesert's Avatar
RainDesert
Very well put.
dpayne75712
6.7L Power Stroke Diesel
16
02-02-2018 10:42 PM
nendayaa_888
32
11-21-2012 12:06 PM
cobrar97
6.4L Power Stroke Diesel
22
11-09-2010 10:31 AM
wahoo
2004 - 2008 F150
21
07-05-2007 03:18 PM
flyguy2
11-18-2005 08:39 AM
Quick Reply: I need honest opinions about the 6.2
