motor swap help,
I think your best bet would be to pull everything from your '94 donor (if you do have the whole truck) and put it into the '87. The wiring harness, computer, etc. will just be too different going from carbureted to fuel injected, IMHO. Swapping the dash might also alleviate some wiring harness issues. It's common with the Bronco II's to swap in a later model 4.0L and usually includes bringing over the newer dash if going into a 1st gen. for that reason. Also in the 1st gen the harness passes through the firewall while by '94 there was a connector at the firewall, so you will have some minor cutting and patching there. If you have only the engine your work may be significantly more difficult. You may need to bring the newer transmission over too...
Building_Fords
10-21-2015 08:07 AM
65F100project
08-24-2006 11:09 AM
