7.3 Starts, Straight to Crazy RPM's
Hey guys, I have a 7.3 naturally aspirated with BB code injectors. Went to start it up one day and it grenaded the IP.
No big deal. I bought a used pump for $50 and it supposedly ran when it was pulled. Got it put on and started it up. Once it hit, RPM's shot through the roof. My tach doesn't work so I have no clue how fast it was turning.
Anyone know what the deal is? Any help is appreciated. Thanks in advance!
Sounds like someone took the top cover off and didn't reseat the fuel shut off when they put it back on.
Edit: unless the truck still shuts off with the key, then the FSS is still working. In that case I'd say your throttle cable isn't routed properly and it's holding the throttle open.
I am very much NOT an expert when it comes to IP internals, however this manual may help. Section 1, sub-section H explains the operation of the me mechanical governor used to control engine speed and has detailed pictures and diagrams of each part.
http://www.motor-talk.de/forum/aktio...hmentId=730171
I don't know where you sourced the IP, but if there is a chance someone already monkey wrenched it you might be better off getting another IP... I just pause to wonder how else the governor linkage would get out of adjustment and why the pump was being monkeyed with in the first place...
I looked at it briefly. The flyweights looked fine but up top, the governor arm did not contact the linkage up top. I adjusted the linkage so it contacted the arm but it didn't help. I'm sure the problem lies here somewhere and maybe I just don't know how to fix it.
Julian Kalamaha
02-19-2018 12:43 AM
citka
09-30-2017 08:50 AM
Mattv7.3
08-16-2017 09:55 PM
