Jolly Green Giant...2015 F-350 KR DRW
#1531
Received 3,942 Likes
on
I just think they should last longer. At least you saved a few bucks doing it, but still that sucks.
One of the campers we looked at had a full size residential fridge in it, and I though it was great. Easy to replace if it failed. But upon looking further I asked him how they got it in there. It goes in prior to the walls. But if it fails, well, you pull out the big back window. Holy crap...
#1532
on
#1534
on
#1535
Received 5,131 Likes
on
#1539
it looks great..
I'm gonna work on the generator install this weekend.. (if it stops raining long enough.. 2.8 inches overnight.. )
#1540
on
I did find a leak at the regulator....two 30# bottles connect up to this regulator that has a valve to switch from one tank to the other. It also has a little green/red indicator. I pulled one of the bottles...empty. The valve is set to the fuller tank. All should be fine................now it started to leak gas from the pigtail not connected to a bottle. Not supposed to do that. Just came home with a new regulator assy. A local Gas joint wanted $39 for the same thing. Bought it. Then I ended up at an RV join for something else.....$89 for the same thing.......
Everyone......Thank You for the nice comments.............
#1541
on
An electric apartment size one that we purchased last summer. It is bolted down in Theresa's bedroom.
The RV Fridge...Gas or 120vac died last summer. I just replaced it.
#1542
on
Theresa's bunk bed I built.........
Just to the left.....doorway going into the kitchen........
#1543
That connection is fine........I even lit a match to double check......................
#1545
Received 3,502 Likes
on
New fridge looks great! I'll keep my fingers crossed that it last longer then 5 years this time.
