my 74 f350 sat for a week, the engine is a 351m or 400 ,not original to the truck. I started it. it ran for about a minute with my foot on the gas to warm her up. i backed off the throttle she just quit fast, and wont start now.
i have power to the coil, and the test light lights up from negative on the coil to positive on the batterie. i did go to napa and buy and replace the coil anyway .
it gets gas to carb and i spray either and nothing,
i thought maybe i flooded it, let it sit overnight and today no start.
Well, if it won't fire with ether, I'd look to the ignition system next. Sounds like you verified that the coil is good; check to see if you're getting a spark.
yes i will when the weather breaks. i am ttrying to get a jump on what it could be.
Timing chain or gear ... or dizzy gear sheared or loose . Hope the points and condensor or wire inside the dizzy is grounded out .... Best of luck ! Let us know what you find .
I personally wouldn't invest too much time & money into making the old school points & condenser work when there are so many electronic ignition options available.
