Replaced Steering Box - Now a Growl
Old 12-09-2014, 12:15 PM
Square Grouper's Avatar
Square Grouper
Square Grouper is offline
Replaced the stock box with a red-head. Truck steers great! But now every so often when steering I hear a slight "growl" for a couple seconds. Any ideas??
Old 12-09-2014, 12:58 PM
Carolina Rig's Avatar
Carolina Rig
Carolina Rig is offline
Mine did that too - it's air in the system. It will eventually work its way out.
you can turn the steering wheel lock to lock periodically to assist in getting the air out, but it will eventually go away.
If I recall, I heard those noises for maybe a week or so, intermittently, after I installed mine.
Old 12-09-2014, 01:32 PM
Square Grouper
Awesome I appreciate the info!
Old 12-09-2014, 05:57 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Put the reservoir under a vacuum and
then do a stop to stop wheel turn and you
will get it out faster if it bugs you. Also
depress the brakes to remove any air
from the accumulator. Once your done
check fluid level.
Sean
Jmoen7
02-27-2015 09:35 PM
xbox73
01-14-2013 06:40 PM
woodyf1
01-30-2010 11:47 PM
bluthunder
07-24-2008 09:58 PM
cactusbronco
1978 - 1996 Big Bronco
09-26-2005 07:41 AM
Quick Reply: Replaced Steering Box - Now a Growl
