Need shopping advice 2015 F250 v.s. F350
#31
I love my new 250. I love my 6.2.
I never considered a 350, as I didn't need the extra towing capacity. And I feel like the ride gets harsher as you go up, unless you are always hauling a trailer.
I have an XLT, and while I wanted the leather, I didn't want to pay the extra cost. I can add leather to the seats if I want, with custom fitted replacement.
I think you need to consider what you need it for.
#32
The towing capacity is the same between the F-250 and F-350. The suspension is also same between the two, except for the taller block that the F-350 has. In other words, they ride the same too.
#33
Weighing In
I don't know how other states charge for registration but there could be additional cost. Do they charge actual vehicle weight or max GVWR, might not be much but something to consider if additional capacity isn't needed on a regular basis and there's considerable cost.
A few years ago my state adjusted the weight brackets tipping my truck and van into next bracket.
-Dan
-Dan
#34
My experience has been the exact opposite. Agreed my 2011 F-250 6.2 could do everything my 2012 F-350 6.7 can do. But no way was it able to do it as easily. Even with the Super Springs I added to rear suspension of the F-250. With my typical loads the F-350 wins hands down. Of course the HP and torque of the 6.7 does weigh in heavily on this debate. I guess every one will have their own take on this debate but I will still stand by the heavier rated F-350. So says the Builders Spec Sheets. Now as to whether they are truly identical, well, only FOMO can say but they are not talking.
When speaking about single rear wheel trucks, we don't need FOMOCO to weigh in - yes, the numbers are different, but the hardware (except the overload spring and spring block height, as mentioned) is exactly the same. The overload spring and taller block can be easily added to a 250, and now you have the EXACT same truck as a 350, sans the badge. Legally, the numbers are different. But physically, they are the same truck.
#35
-Dan
-Dan
3BadBirds
10-14-2009 10:42 PM
Jet Jockey
2004 - 2008 F150
11-12-2008 09:55 AM
