GT40P head questions
Would cast iron HIPO 289 manifolds fit the GT40P heads? I know of the different plug angle which Ford solved by using some wierd looking headers.
Would there be any interference with putting on plug wires?
I have a 3.08 axle ratio, so the 302-4 bbl engine doesn't rev up too fast (1800 at 60 mph, 3500 in passing gear), but it is real torquey with original stock heads and a 268 comp cam. Or are the rpms kept too low for the heads to make a difference?
Thanks.
Thanks.
on
At 1800rpm.. if that is your cruising speed this motor is outside it's "powerband" which is something like 3000-6000rpm with that cam and heads. There is nothing wrong with that you just have to accept downshifting as a fact of life and not be afraid to let her scream once in a while.
Can't help you with the manifolds, but from what I have seen you can make standard 302 headers fit these heads you just have to be prepared to message a few head tubes to clear the plug boots.
ryan f150 4x4
12-17-2009 09:25 AM
redneck[><]
02-15-2006 01:35 AM
