Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-09-2014, 02:12 AM
rockittsled's Avatar
rockittsled rockittsled is offline
rockittsled is gaining momentum as a positive member of FTE.
So, had a bad day a couple of months ago
I was up in North Carolina for a contract and had to come back to Jax for a VA apt. Drove back with no problems, took a nap, got up and headed to Southside for the appt. I was coming up on the Baymeadows exit when "CRACK!KNKNKNKNKNKNKNK!!!" I took the exit and made it to the Gates gas sta, jumped and popped the hood to look at the exhaust manifolds(I knew one was cracking, I thought it had broken) and noticed a growing puddle of oil underneath the engine. I hollered at my wife to shut the engine down and looked under and saw a hole in the oil pan! After we got towed back to the house, it had cooled down for me to stick my finger in the hole and felt lots of chunks, including a rod bolt still attached to part of a rod, and the oil pump driveshaft. Got online and found a 360 in Crystal River, FL for $250 on CL. Got up Sat morning to go get it, got there and recognized the blue F100 4x4 from here on the forum in the Bump side. (I do not remember his avatar name, unfortunately, but I am pleased with my engine) Had to go back to NC to work for another month, but I finally got back down here to put the engine in to my truck at the NAS Jax Auto Skills Center
LOOK HOW CLEAN THIS ENGINE IS!! Rebuilt and .010/.010 on main and rod THANK YOU AGAIN
__________________
76 F250 390 4V C6
Old 12-09-2014, 02:24 AM
So the plan had been to pull a main and a rod cap to check it out before I dropped it in but WOW was it clean, so I just pulled the dead 390, dressed the 360 and put it back together
CLEAN!!
Getting into my work
__________________
76 F250 390 4V C6
Old 12-09-2014, 02:38 AM
Postmortem pics of the dead 390
Oil pump pieces, notice the base of the pump is still bolted to something
#5 rod came apart and whipped the pan rail and oil pump boss right out of the block
__________________
76 F250 390 4V C6
Old 12-09-2014, 04:03 AM
privateer, eh's Avatar
privateer, eh privateer, eh is offline
privateer, eh is gaining momentum as a positive member of FTE.privateer, eh is gaining momentum as a positive member of FTE.
That looks viscious, Good thing a Fte'r had what you needed. Had the same experience with a 75 Dart sport with a 225, replaced it with a 340 4 speed from a 69 Dart gtx. 3 weeks later I blew the rear end out at Gimli raceway, twas the start of an expensive summer. Got lots of qualifying runs in, made it past the 60' line in competition twice in 9 tries.
__________________
Privateer, eh
75 F250 Camper Special 390 - Katy P
79 F350 custom cab 351 - Gut Bucket
78 F350 Custom Cab 400 - Henry (Glen's Ghost)
89 F350 Dually Chassis for 78 F350
http://s1343.beta.photobucket.com/user/Perrycolp/library/#
Old 12-09-2014, 04:11 AM
So, an observation or two on the dead 390
1 I had assumed that my truck has 264000+miles, not the PO stated 164000, based on the rust on the body, tightness of the front suspension with the radius arm brackets bolted rather than riveted on, bad Ujoints, and other things ie a work truck that was well taken care of until it was parked.
2 The truck was sold in WA, spent time in CA (CARB Engine swap sticker on the door jamb to a 360), then ended up in Lake City, FL working on a ranch
3 The engine had been swapped back to a 390 before I had gotten it, but I figured that since the timing cover and intake manifold both showed signs of silver paint, someone had already been in it and had rebuilt it
Nope, it still had the nylon toothed timing gear, 410 marked pistons, shim gasket and Ford marked bearings and no ridge on the cylinder walls, I polished off the carbon with a Scotchbride and it was almost smooth
If I would have known it was still untouched, I would have looked for another eng and put a simple rebuild on that to run with, and rebuilt the one in it with all the glory parts
__________________
76 F250 390 4V C6
Old 12-09-2014, 04:14 AM
Quote:
Ouch, my sympathies
__________________
76 F250 390 4V C6
Old 12-09-2014, 04:24 AM
Yer only 16 once, probably why I haven't aged a day in the 37 years since Lol. Actually, now you can rebuild that motor at your own leisure, they're usually cheaper that way and last longer. Outside of machining, cam and internals every thing else can be bought used.
__________________
Privateer, eh
Old 12-09-2014, 04:40 AM
On the 2nd pic of the third post, that lump to the right of the oil pump, is the top of the oil pump still bolted to the boss that is supposed to be part of the block, I can just imagine how much that would cost to repair cast iron like that
__________________
76 F250 390 4V C6
Old 12-09-2014, 01:05 PM
Took a 2nd look at the pick and yes I must agree, that would be a hard part to weld back into the block. I've done to much salvaging/repairing in my days and sometimes I need some time to realize " I aint doing this with my skills, scrap bin! ". If I don't have a reasonable chance of fixing it myself I don't send it to my brother unless it's a must have situation.
__________________
Privateer, eh
Old 12-09-2014, 02:55 PM
good to doo good to doo is offline
good to doo is starting off with a positive reputation.
Are you sure you didn,t drive that thing in to a lake and hydraulic it. My god that is some carnage.
Old 12-09-2014, 04:21 PM
Not only did it run for about a mile before I came to a stop and shut it down, it actually started up and ran enough to back it up the driveway about 6ft a month later.
__________________
76 F250 390 4V C6
Similar Threads
Manifold Heater Hose Elbow rockittsled 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-04-2014 11:26 AM
New steering coming together napass2004 1961 - 1966 F-100 & Larger F-Series Trucks 29 03-03-2014 09:08 PM
Mater Lives!!! rockittsled 1967 - 1972 F-100 & Larger F-Series Trucks 6 02-21-2014 01:12 AM
DSO code info for my options rockittsled 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-22-2012 03:25 AM
Please post pix of old decals found on our trucks rockittsled 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-20-2012 05:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
