Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-08-2014, 11:44 PM
dbdbb dbdbb is offline
dbdbb is starting off with a positive reputation.
Starting troubles
Hello all, I have a 95 F-350. I recently put the body and engine from a 2 wheel F-350 onto a same year 4X4 F-350 frame. I changed both the ECM and PCM from the 4X4 frames cab into the 2 wheel cab (4X4 is auto, while the 2 wheel was man.) I now have a 7.3 4X4 auto.
The truck starts right up when cold, not plugged in with one cycle of wait to start during 10 degree weather, it starts right up when hot, just shut off.
If it sits for a half hour after operating temperature, it will not start!!
I don't know why this type turned bold, after it cools back down to cold, it will start right up again. When it's been sitting for half hour or so, it spins over really fast, just won't fire. No smoke or anything.
The engine had a fresh oil change with Rotella 15w/40 while out, and the oil is full at the moment. I swapped out the injectors from a smooth running engine, (previous rough and violent shake at idle)with all new injector O-rings. Less than 150 miles since all this work was done. There are no mods other than adding the BB into the pressure regulator.
Bear with me, as I don't know what an ICP or IRC is or where they are located. I did a search on here for my problem, and I found these initials with no definitions. All Greek to me.
I have a low dollar OBDII scanner, no codes with the key on, engine not running, I tried to run a scan with the engine running, and the scan kills the engine, just like you shut the key off then turn the key back on.
My question is, why won't it start in the in-between range of temperature. Any help would be greatly appreciated, thanks. D.B.
Old 12-09-2014, 01:01 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE is starting off with a positive reputation.
Your code reader probably doesn't link to the pcm. These trucks seem to take a special breed of scanner. When you put the new orings on did you oil them up real good. If there is a few damaged ones it could cause this. Try unplugging the icp (injection control pressure sensor I think) it's mounted on the driver side head towards the front. I'm pretty sure it's a round plug. If it has any oil in it it's probably due for replacement. Ipr is injection pressure regulator mounted right below the hpop. It could be ipr orings as well. I have the exact issues you have and am planning to address them Wednesday. Whomever figures it out first please post it
__________________
It's hard to soar like an eagle when your flying with a bunch of turkey's
1997 F-350 xlt cclb PSD 4x4 zf5
1989 F-350 4x4 7.3 c6 auto retired
2000 F-150 XLT 4x4 4.6 e4od
Nick
Old 12-09-2014, 06:58 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
Plumb a mechanical oil pressure gauge. You'll need a gauge good for at least 3000 psi, a whip (hose), and a male end of #5 ORB.
Either that, or check what your ICP is reading by hooking up a scan tool. You can use a Bluetooth OBD-II dongle and the Android app "Torque Pro", if you have Android. The app costs $5 and the Bluetooth dongle is roughly $12 on amazon. I HIGHLY recommend it; it is the most impressive android app that I've ever seen.
__________________
'88 F-250 6.9 IDI ZF-5 4x4 Standard Cab ?? Miles
'94 F-250 7.3 PSD ZF-5 4x4 Standard Cab 374k Miles
'67 Mustang 289 C4 "Who Cares?" Miles
Old 12-09-2014, 07:13 PM
Injector O-rings were dipped in oil before installing on injectors, then the injectors were slathered in oil before installing in the heads. I drove the truck today to warm it up and then let it sit, it ended up sitting longer than I wanted before I could try to start it again. It didn't start, so I unplugged the ICP (I think, the plug with 3 wires going into a round device on the driver side front of head), there was no oil in the plug, but the engine started with that unplugged. I don't know if that being unplugged is what caused the engine to be able to start, or if it had just cooled down enough to start again. It was much colder today than it was yesterday, 25 Deg. today as opposed to 38 Deg. yesterday.
Lemonshindig; What is a #5 ORB? And what hole would I screw this into? I will look into the dongle, but I have no idea what that is. I do have an Android phone and an Android tablet, so I will look into the app. as well. Thanks guys for your help so far, D.B.
Old 12-09-2014, 07:34 PM
It's a -5(size) O-Ring Boss fitting
__________________
Nick
Old 12-09-2014, 11:58 PM
fordman67 fordman67 is offline
fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.fordman67 has a good reputation on FTE.
If you can get it to not start then unplug the ICP sensor.if it does start then you may just have a bad sensor.when it is unplugged the pcm assumes a certain amount of oil pressure.yours is most likely and telling the pcm there is not enough pressure to fire the injectors when in fact there is but the signal is incorrect.
Old 12-10-2014, 10:22 PM
I tried unplugging the ICP today when it didn't want to start, and it didn't help, still no start. I have ordered the OBD II bluetooth dongle, it should be here Tuesday. I don't need the truck for daily driving, so I think I will wait until I can see what the computer is showing.
Old 12-13-2014, 06:35 PM
I got the dongle and app today, it doesn't seem to be very compatible with my truck. Only thing that shows is the rpm. If I try to run a scan, if I'm not holding a high rpm, it will kill the engine. Then it says $06 can't something with ecu.
I may have to try a manual gauge.
I haven't driven it with the Torque app running, maybe try that tomorrow.
Similar Threads
Won't start sometimes bradahl 1997 - 2003 F150 4 08-21-2014 06:20 AM
4.9 hard starting problem after sitting 88B_RONC 1987 - 1996 F150 & Larger F-Series Trucks 0 06-24-2014 01:42 PM
2005 F-350 won't start mjwiens Super Duty & Heavy Duty 1 05-11-2013 12:05 AM
2004 ford 6.0 won't start Huxlet 6.0L Power Stroke Diesel 21 02-27-2013 01:15 PM
Looking for advice on AE readings..no start Philip Berardi 1999 - 2003 7.3L Power Stroke Diesel 16 09-22-2012 08:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
