T-bird / Mark VIII IRS swap
The kit has been around for quite a bit. I did mine with the kit about 3 years ago. I would have to look at the dates of my posts for an accurate time frame. Ok I went and looked. I did mine in October 2011.
Yea they been making the kits for awhile now. My buddy actually had one of those kits on his truck around the same time as you. Fitment and ease was good he never finished the truck though before he sold it so I don't know how well it handled afterwards. I'd like to see how a front and rear independent suspension changes these trucks haven't got the chance yet.
your build is well documented to the point of if you do a google search
its almost always your truck that come up
I have seen a couple pics here and there of others that have done the swap
but that's all there is a couple pics
I hung a 8.8 from an explorer under mine and it's too narrow !
from what I have read the (mark) rear is a couple inches wider
P.S. Im trying to sell my 5 on 5.5 factory slot mags $200 plus the ups ride
The later model truck is yellow if memory serves me right. The frames are 34" wide from '53-'72 so info from guys with different trucks would apply. The frame may extend even farther back.
I would look to the '53-'56 guys. Something tells me you might have decent luck finding info there.
I love this web site search around long enough and you will find everything your looking for
found this build on the 61 to 66 page
https://www.ford-trucks.com/forums/1...100-build.html
built his own mount kit that blows team 321 away !!!
I believe in the C.A.S.E. method when it comes to doing a custom build
if you see something that works
C. copy
A. and
S. steal
E. everything
C. copy
A. and
S. steal
E. everything
The following users liked this post:
Something you might want to consider. I seen pics somewhere of an install where they cut the front mounts off and bolted them directly to the bottom of the frame rail. They then fabbed what they needed to reattach to the original subframe.
I wanted the ability to bolt in a replacement with no fab work if need be so I did not go this route.
The yellow truck with the IRS is a 1988 model F150 owned by Shaun Draycott, who goes by the name 'Sportruk.'
https://www.ford-trucks.com/forums/7...uspension.html
IRS Axle Photos by Sportruk1 | Photobucket
