Unsure if glovebox tag is correct
I have a 1959 f100 2wd 3 on the floor(according to the vin). But its a 4 wheel drive 4 on the floor. im thinking the vin plate is wrong the plate says: Vin:f10c9exxxxx
wb:118
color:U
Model: F18c
Date:26h
trans: A
Axle:02A
Any help with figuring this out would be greatly appreciated
wb:118
color:U
Model: F18c
Date:26h
trans: A
Axle:02A
C = 292 2V
9 = 1959.
E = Mahwah NJ Assembly Plant.
118" Wheelbase.
U = Meadow Green.
F18C = F100 4WD, 5,600 lbs. GVWR
26H = Assembled August (H) 26, 1959.
A = Ford 3 Speed Manual Transmission (Note: F = Warner T-98 4 Speed Manual Transmission).
02A: 02 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity // A = Spicer 44 Front Driving Axle / 3.92-1 / 3,000 lbs. Front Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
1959 & 1960 F10 series code refers to both 2WD & 4WD. Only the MODEL code defines 2WD from 4WD
Your MODEL code is F18C = F100 4WD, 5,600 lbs. GVWR / If it was F100 or F10C = F100 2WD, 5,000 lbs. GVWR
1963 Ford Truck
10-18-2017 04:57 PM
amaidemon
08-17-2012 11:49 PM
