97 F350(old body style) Bolt Pattern Question
1997 F350, crew cab long box, 7.3L power stroke. So I am finding the old 16 inch tire size hard to locate used anymore. Thought if I am going to upgrade to new tires, maybe I should look at a set of factory take off's with rims from a newer F350. I hear Ford changed bolt patterns shortly after but have no way to confirm to when and what year works on the old style so here I am with a question.
Up to what year F350 will fit my 1997 Bolt pattern? Lots of deals with rims and tire combos on the newer stuff so thanks for the info. It's appreciated.
Ed
Ed
OBS = 8 x 6.5" lug spacing
SuperDuty body stye = 8 x 170mm lug spacing
Inexpensive newer take offs seem to be everywhere…. I picked up a set of 6.5" to 170mm adapters just to keep in case I got stranded and needed tire options. Not a long term solution mind you, just to get out of a bind.
Mainesupercrew
03-08-2009 09:14 AM
CE-f250
01-13-2009 07:49 PM
