got a little hard start after fuel bowl repair.
Old 12-07-2014, 05:56 PM
carl2591's Avatar
carl2591
carl2591 is offline
recently did a fuel bowl o-ring replace due to fuel leak at drain dog bone looking thing on back.
Got the mil spec o-ring for drain valve and replaced all o-rings and replace fuel line rubber seals on fuel lines.
I did the key on thing several times, once with drain valve open for several seconds, to purge air, and after getting started shut it down.. I took truck out saturday for several errands and the spin over time was a bit longer than normal.. Thought it might be a bit of air still so when in interstate i came off exit ramp onto road and mashed the gas for a bit. no miss or anything else that indicated air so when we got to store i shut off.
coming out and starting again took longer to catch. could there be more air in system i am not getting out.. drive time was only like 15 mins or so at 1800 rpm in OD. This was one of several stop on sat and each time it took longer to catch.
any suggestions. ??
Old 12-08-2014, 07:02 PM
F350-6's Avatar
F350-6
F350-6 is offline
It's not air in the system if you cycled the key on for 20 seconds several times. Doesn't sound like it's related to the fuel at all.
How's your oil level?
MTRoofer
19
10-23-2012 11:47 PM
Swimholm
11-03-2011 10:52 PM
texasf350
12-19-2009 10:46 PM
UP_There
17
01-20-2008 02:45 PM
buzzcutt2
12-11-2005 06:51 PM
Quick Reply: got a little hard start after fuel bowl repair.
