1997 f250hd 7.5 running rich
Old 12-07-2014, 09:59 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Originally Posted by craftsmangary
I just looked in Mitchell, 5.0, 5.8, and 7.5 49-States are all plumbed the same way, looks like the same diagram, you better look at it.
CANP is plumbed to the atmosphere side on 5.0/5.8L engines
Good example VECI label for 5.0/5.8L engine trucks:
7.5L engine trucks may be going to manifold vacuum:
There is a pic in this link below where it shows the CANP does indeed go to manifold vacuum on 7.5L trucks. I recently learned, then overlooked again, how the 7.5L engine trucks have different EVAP system hose routing.
https://www.ford-trucks.com/forums/1...l#post14530413
Old 12-08-2014, 03:52 PM
craftsmangary's Avatar
craftsmangary
craftsmangary is offline
I looked at Mitchell and Alldata, On the Alldata diagrams I can't even read the text, it's a poor diagram. On some of the Mitchell diagrams it shows one side of the can p going straight to the throttle body and the the other side of the can p solenoid going to the charcoal canister and there is a "T" on that line, the "T"ed hose goes to the other side of the throttle body.
Old 12-08-2014, 08:15 PM
brodie429's Avatar
brodie429
brodie429 is offline
I did check the fpr and vaccum line no fuel present , there isn't a leak at the canp solenoid . After reading another post I tried changing the intake air charge sensor,before that the o2 sensor wouldn't switch between open and closed loop it now does . it is better ,but still smells rich
Old 12-08-2014, 08:32 PM
craftsmangary
Did you put a gauge on it to test fuel pressure? You should have 28-45 psi with the engine running. With the engine idling it will go in and out of closed loop. If it was running rich the sparks could be fouled, I'd pull a few out and look at them.
Old 12-09-2014, 07:21 PM
brodie429's Avatar
brodie429
I did use a gauge , the pressure running was 38 , with the vaccum unhooked it was 45 . before I put the air temp sensor in it wouldn't switch from open to closed . pulled a few plugs and they are light brown . the exhaust still smells rich , burns your eyes and throat
Old 12-09-2014, 07:52 PM
rla2005's Avatar
rla2005
38 PSI fuel pressure at idle? That seems high to me. I would expect to see 30-32 PSI. Perhaps 7.5L trucks use a little higher pressure than the 5.0/5.8L engines.
Old 12-09-2014, 08:25 PM
craftsmangary
Does the scanner you are using show fuel trim?, short term fuel trim and long term fuel trim and what are the numbers?
Moore558
03-09-2008 01:30 PM
GREEN 94 RANGER
1983 - 2012 Ranger & B-Series
02-15-2008 10:38 AM
timothy47129
Bronco II
10-12-2006 02:02 PM
68cougarrrr
12-23-2005 09:35 PM
Chickenmantoo
Bronco II
11-11-2003 08:50 AM
Quick Reply: 1997 f250hd 7.5 running rich
