94 f250 fires but won't run
There are a lot of videos on Youtube. I like this one. Note the spray pattern as it cleans.
That settles it, fuel problem. You may also want to check the injectors for actuation using a mechanics stethoscope.
Yes.
Really thought Conanski had it nailed with the wiring harness, but sounds like you used the original harness to the truck.
on
If so you have a MAF harness on that motor and that won't work.
ok, I used the harness for the 95 motor but the original harness for the engine bay(94). Both the 95 and the original 94 engine harness have the same number of wires and in the same place as each other.
I'll try to check the injectors for operation instead of just signal with a noid light. I'll also try a little gas in the intake to see if it will run longer.
I'll repost after i try this.
thanks for the suggestions.
Ok fellas, I put it back together and squirted some gas down the intake and it started and ran for 2 or 3 seconds. So obviously I've got a fuel problem. It looks as if I'm into changing out some injectors. What do you fellas think about getting some rebuilt units off EBAY? I've never had to buy injectors before. At least I've got a direction that looks very promising.
Thanks for all the help, I'll post the results, which I'm pretty sure they'll be positive.
JCFranklin
02-28-2019 08:13 AM
scouts5454
01-05-2015 08:36 AM
Inline6Rookie
07-23-2013 10:20 PM
clstrfbc
07-16-2006 12:54 AM
clstrfbc
07-31-2004 01:11 PM
