2003 Navigator Air Suspension Pig Tail - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-06-2014, 09:52 AM
risaac928 risaac928 is offline
risaac928 is starting off with a positive reputation.
Hey guys, someone has had to have this issue before. Please help. I replaced the relay and the Air Pump tested O.K.
I think I know why the pump wont kick in and raise the Navigator. This Blue/Yellow wire is not getting any power and I cant figure out why. I am not sure what this Blue/Yellow wire is for . Can someone chime in and help me out.
Old 12-06-2014, 12:40 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
That wire is used by the control module to supply the ground to the relay coil. See the attached PDF.
Old 12-31-2014, 10:55 AM
4srfox 4srfox is offline
4srfox is starting off with a positive reputation.
reply
My suggestion go coil over. Eliminate all go these costly problems. Example: I replaced the compressor, one month later the front was loosing air, than I purchased new bags. Then still wouldnt work properly I had new issues. Finally I said the He.. with it and purchased new oil overs. Under $300.00 and there a dream. Should have done it long ago. You an sell your existing stuff and probably get back your $. I did!
Fuel Pump/sender wiring question aar_man 1987 - 1996 F150 & Larger F-Series Trucks 0 10-10-2016 09:07 PM
Horn brush woes??? asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 12 09-27-2016 12:06 PM
Wiring question fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-10-2015 11:09 PM
94 Lightning Fuel Pump tommyleea Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 0 11-25-2014 09:29 AM
Need stereo wiring help - 1995 Ford F700 thaugen Large Truck 1 07-31-2012 10:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
