Recommendations
If you don't want to "break the bank", just change the plugs with good plugs as noted above.
No reason to spend a dime on CP's until necessary. Even though mines a 5.4, I've changed two individual units in 317,000 miles.
Code came up p0300. That code has a list as long as your arm on the root cause. So...before I start dropping a lot of coin on new COP..plugs etc., lets just start out with cleaning the MAF sensor. From there will be checking vacuum hoses, egr valve and so on. Hopefully it's something simple.
The missfire code (p174) said it was random cylinders, not one specific cylinder.
Anyway, I'll post a report later on whether or not the MAF cleaning helps.
Again, thank you all for your responses.
Glenn
Glenn
Hi again...
Well I had both the 0300 and 0174 codes. 174 is the lean code correct? I've started with cleaning the MAF sensor..that helped somewhat but still not right.
So, before I start messing with COP and plugs, I thought I'd start with vacuum lines etc. The inexpensive stuff, plus with the age of the truck, the vacuum lines probably are starting to dry out.
The truck has been parked now..I really don't want to drive it with the light on, so sunday I'll start with the vacuum lines/PCV valve and related grommet.
Any other suggestions would be appreciated.
Thanks again.
Thanks again.
Hi Alloro...I was told that if there was a bad vacuum, PCV valve, etc that the PCM would lean out the engine, causing the misfires. This is why I first started with the vacuum lines before I jumped into either the COPS or plugs etc.
I've changed the PCV valve..the old one was pretty gunked up and the truck runs better, but it isn't running as it should.
One step at a time, I guess.
Thank you for your response, I do appreciate your time.
Edit: I did clean the MAF sensor..that too helped a bit.
