Plug for in cab tank filler neck
I believe There was a plug to go in the filler neck hole on a exploded parts view I seen posted here before. Maybe for a big F series been awhile so don't quite remember. Also many others made a piece and welded it in but you'd only want to do that if your getting ready to paint it or don't mind painting it and it being mismatched
on
I saw one of those cap plug at PnP a few yrs. back in a bump. I never thought of getting.
Kind of figured since, I've seen a few of them in the pass 20+yrs of scrounging around junk yards that ford had made or stocked them. I Figured if, I ever needed one.
I'd just weld up and be done with it. Maybe someone has one sitting on the shelf like "nos"
I guess should have gotten it, I know a few guy on site have been wanting..
Orich
Orich
I haven't seen any vendors that repops the plugs so chances are you won't find any aftermarket ones. Maybe if you find a company that specializes in making body plugs they might have a size that fits. I don't know why nobody makes them for these trucks. I'd think they would sell pretty good from all the others that asked the same question about how to block off that hole. Orich those plugs would sell like hot cakes if you would of grabbed them at the Pnp
Here's my 2 cents: At Home depot in the drain assembly plumbing parts isle, they have clean out caps that have a hard plastic piece with a rubber disk. When you tighten the wing nut, it expands the rubber to tighten in the pipe...kind of hillbilly, I know but that's what I did in my 70 I used to have. Keeps drafts and moisture from entering the truck.
The optional 25 gallon factory installed auxiliary fuel tank then became a mandatory order for an obvious reason.
And...1967/72 F100/750 Crew Cabs did not come with an in-cab fuel tank. Came w/a inside the left frame rail mounted 17 gallon tank instead.
C7TZ-8144554-A .. Plug-Use to fill hole for in-cab fuel tank filler pipe / Obsolete ~ 1967/72 F100/750.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
No Ford dealer, no other obsolete parts vendor has any.
1969/72 F100/350: Ford offered an optional factory installed tool compartment that took the place of the in-cab fuel tank.
