Peep mirrors..... 1951 F1
Well, my truck doesn't have any mirrors in or on it so I have a fresh slate I guess.
I have run across a few peep mirrors (the ones that hang on the top of the door)
I like the look but am not sure of the quality. I wont be painting the truck (at least not for a long time) so I am not concerned with the allen bolt tightening method (truck is in primer right now)
What does everyone have that is somewhat custom? I don't mind the mirrors that mount to the door pin and have the curve. I don't like the mirrors that are F2 and up with the brackets all over and Im not really fond of the straight arm mirror that mounts to the door hinge pin.
So I am between the peep style and the curved stock style. What are everyone's thoughts?
on
Ya know I don't even know were I got it, one of the vendors at Carlisle swap meet, it's been on there since 1994 when I finished the truck, and thanks all stock with flatty v-8 and stock front end with lowered leaf springs in the front, 6" wide wheels up front 8" wide in back, I wanted that 50s hotrod look
Mine were from Speedway Motors. I also purchased the extenders but I eliminated the door clamps and bolted directly to the door.
__________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"If you see my Truck on a trailer, call the cops, it's being stolen"
I have the peep mirrors with the directional indicators and by adding on the 1 1/2" extenders from Speedway Motors I'm able to see behind on both sides.
"Practical first, looks seconds".
"It's all stock except for the Hypo muffler bearings"
I had the peep mirrors. I couldn't see anything out of them. One fell off one night & I couldn't find it. I was on a country road driving along at around 50 mph....so that one is gone.
I got rid of the other peep and went with a hinge mirror on the driver side only. That was a little chore, but it is usable for driving.
I may add a hinge mirror to the passenger side someday. It's not really all that necessary except when backing out of the barn. It would be nice to see the clearance between the fat fenders and the edge of the barn door!
Dan
Dan
Long time since I started this thread. I ended up with the 4 inch peep mirrors. I wanted the Curved door hinge mount mirrors but my hinge pins are most likely too much work to get out. If I ever do end up removing the doors I will do the hinge mounts.
I got in the truck, sat and pretended to mimic a driving experience and either mirror would really work for the amount Id use the mirrors.
I got a set similar to 48steel's and will install them in a similar location as well.
