06 f350 3inch lift or level kit?
If you look in my pictures mines got a 6 inch lift kit
Just keep in mind when you lift kit and also keep in mind you will lose some of the ride quality and I'll be more stiff and you'll feel every bump in the road
And if you use your truck for work like I do it kind of sucks lifting all that stuff that extra little bit higher
But the bigger the lift kit the more badass no doubt about that
Here u go this should help,
I pull a 5'er & this Height is as far as I felt I could go doing that safely
My 2006 F250 KR
Suspension Modifications:
Pro-Comp 2.5 Front / 2.0 Rear Suspension Lift
& Rancho RS9000XL Adjustable Shock's
Wheels/Tires Modifications:
18x9 XD series "Hoss" wheels by KMC ( 18 offset)
& 305/65/18's (33.6 inch) BFG All Terrain T/A KO Tire's
My 2006 F250 KR
My 2006 F250 KR
My 2006 F250 KR
Yes, on a very tight turn when I'm against the stops. I'm running a Toyo M/T 35x12.5x20. I tried the new R/T and they didn't rub. So a tire just slightly narrower shouldn't rub. It's because the M/T has the bigger square shoulders and the rubber goes down the sidewall. With some tread wear it will stop. Bought the truck used, PO said they rub for a few months after he got the new tires.
