Questions on rearend dimensions
Old 12-04-2014, 06:55 AM
l8000's Avatar
l8000
l8000 is offline
I am beginning work on a '56 F-100 and trying to get some numbers straight so I can round up some parts. The plan is to do a CV IFS swap from a P-71 Police Interceptor and retain the 4.6l V8. The CV automatic trans will be swapped for a cheap T-45 5 speed out of a Mustang. I also want to install an 8.8 rearend complete with disc brakes that should hook right up to the CV master cylinder.
My only worry is finding the right width of 8.8 that will fit between the fenders without some crazy offset for the wheels. I can get a complete 8.8 from an Explorer with disc and a companion flange for the u-joint for $100. I will jump on this immediately if I know that it will fit with tires between the fenders. What do you guys think?
Old 12-04-2014, 07:18 AM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Here is a link that gives all the fitment info you should need.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps - Ford Trucks
Old 12-04-2014, 07:36 AM
l8000's Avatar
l8000
l8000 is offline
Looks like it'll work. Thanks for the link. I'm going to jump on the axle.
Kosta72
05-02-2019 11:32 AM
GoldCo
04-20-2016 11:12 PM
79Ford4x4
Offroad & 4x4
20
02-18-2010 09:35 PM
FORD{TR}UCKS
1983 - 2012 Ranger & B-Series
12-10-2004 10:55 AM
CanadianCobra
12-11-2003 02:11 PM
Quick Reply: Questions on rearend dimensions
