Questions on rearend dimensions - Ford Truck Enthusiasts Forums
Old 12-04-2014, 07:55 AM
l8000 l8000 is offline
l8000 is starting off with a positive reputation.
I am beginning work on a '56 F-100 and trying to get some numbers straight so I can round up some parts. The plan is to do a CV IFS swap from a P-71 Police Interceptor and retain the 4.6l V8. The CV automatic trans will be swapped for a cheap T-45 5 speed out of a Mustang. I also want to install an 8.8 rearend complete with disc brakes that should hook right up to the CV master cylinder.
My only worry is finding the right width of 8.8 that will fit between the fenders without some crazy offset for the wheels. I can get a complete 8.8 from an Explorer with disc and a companion flange for the u-joint for $100. I will jump on this immediately if I know that it will fit with tires between the fenders. What do you guys think?
Old 12-04-2014, 08:18 AM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is online now
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Here is a link that gives all the fitment info you should need.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps - Ford Trucks
Old 12-04-2014, 08:36 AM
Looks like it'll work. Thanks for the link. I'm going to jump on the axle.
69 f 100 cv swap jdsims25 1967 - 1972 F-100 & Larger F-Series Trucks 1 01-12-2016 09:15 PM
Question for those who have done the crown Vic swap wa-sleeper 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-29-2015 07:57 PM
4.6 police interceptor swap HELP bigbaddorsey Modular V8 (4.6L, 5.4L) 11 01-24-2015 08:15 PM
CV Swap gongchuan 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-06-2014 06:08 PM
Rearend Swap - 2000 8.8 dwardle 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-28-2009 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
