Alright the truck has 18-19 inches of vacuum at idle and it holds steady while reving 3k with the truck just sitting. Didnt seem slow to return to normal. Also I unhooked the vac line to the regulator and the fuel pressure went up to 39psi. Got a new wix fuel filter today but its dark already.. Project for tomorrow I guess
Doesn't appear to me that you have a fuel pressure or vacuum issue, so I'll mention that the solution to a similar problem in another thread was to replace the MAP sensor. I have not read this whole thread either so I'll ask have you pulled the codes?
I think his fuel pressure readings are on the low side IMHO.
They may be a touch low but that could be attributed to gauge tolerance or if the needle is bouncing just measurement error. In any event there is enough pressure there that it won't limit the engines ability to rev, that will only happen if cruising pressure is down in the low 20psi range and drops at WOT.
Well I was gonna pull the codes but I couldnt get the check engine light to come on. Pulled the gauge cluster and sure nuff somebody pulled the bulb out. I stole one of the others I knew worked but it still wont come on... Something interesting happened while I had it idling though. It dropped down to 500 rpm about died then reved back up to just under 1000rpm were it usually stays at. It only did that one other time so i ignored it. Could that be a symptom of a bad MAP? Anyways I still gotta do the fuel filter and run around with the vac gauge hooked up now
Alright driving the truck 3rd gear at 3000 rpm she is in the 15in range for vacuum. Then at the point where it wont rev anymore it would stay between 10-15 depending on how lead footed I was. And at WOT to the point it wouldnt rev anymore it dropped to zero..
