road draft tube?
you would be better off to replace the CDR with one that works. it does the same job as a PCV on a gasser, keeping crankcase pressure down, which minimizes leaks and everything else.
however, if you insist on getting rid of it, you basically need to plug its hole on the intake manifold, and put a pipe from where it connects in the valley down toward the road.
1984F2506.9
13
05-14-2014 07:17 PM
trucktex941
01-22-2008 05:46 PM
kaufhaus
11-06-2003 03:31 PM
