The switches are replaceable on some assembly models, but not all. Generally, the entire assembly needs to be replaced when cleaning does not work. I have ordered from what used to be Tousley Ford with huge discounts on genuine OEM Ford components. They are now AutoNation at White Bear Lake...
I think the ones that have the replaceable sensor do not have the adjustable pedals. The ones with adjustable pedals you must replace the entire pedal assembly.
I was lucky and cleaning my sensor with electrical cleaner fixed my problem.
It's not even that straight forward. My F250 does NOT have adjustable pedals, but the switch is still an integral part of the assembly and cannot be replaced by itself... I've been down that road twice now in the past 8 years.
Ahh, guess I'm lucky on my f250, Excursion not so lucky
