no power to fuel pumps
As long as the pump puts out 45psi fuel pressure and you run a return line from the fuel pump regulator back to the can.
You will also need a fuel injection filter between the pump and the fuel rail.
The fuel hoses for the pressure side must be fuel injection rated with two fuel injection hose clamps on each end of the pressure hose.
