want to add running lights to my step bars, suggestions for wiring please
I am a trucker at heart and I like to add running lights to my running board / step bars. As far as installation of the lights, done it several times, no problem there. However in the past, I have just ran a wire back to the trailer plug and used a scotch lock / snap connector to feed the running board lights.
if I do the same on a 2012, will that cause havick with the computer? Most likely I will be running 7 lights, all 3/4" diameter LED style.
If this isn't' the best solution, can anyone suggest where to get power for marker lights.
thanks!
thanks!
I tapped the license plate light wiring as it was the easiest to access. I would also use a small wire loom to protect the wire as you run it along the inside of the frame. But stay away from scotch locks., at a minimum use a good crimp butt connector with shrink tubes. You will have no problem with the extra load with that few of lights.
This member did a really good job with his..
See if this helps you..
2004 F250 Marker Lights
I'm planning on something similar in the same location he used only more of them in a LED like I have on the reefer trailer I pull..
Truck-Lite - Catalog Product : Model 35 Combo Marker & Clearance LED Sealed 5 Diode Pattern
Check out this members thread. He also has a link to a site he runs about how to wire his running lamps along the bottom of his doors.
https://www.ford-trucks.com/forums/1114231-a-few-lighting-projects.html
Here I linked to the exact project. If this is sort of what you are looking for.
http://www.frontiernet.net/~jmray/F250MarkerLights.htm
