I took my truck in to have them take a look at my cooling system before I do the blend door myself if it comes down to that being the problem. I will update when they get back to me sometime later today. I'm wondering if there could be a trapped air bubble in the coolent system causing this somehow since I just had the radiator replaced a few months back.
If you do have to do the blend door, there is a short cut product that saves you having to take the dash out by going through the back of the glove box with a metal replacement door. Look up Heater Treater.
You can even save your money by purchasing a Dorman blend door replacement that has an adjustable metal sleeve for easier installation. The Dorman blend door is about $25, the heater treater is $119.
I took mine in to have a new flowmaster dual exhaust installed and figured I would have them take a look at the heat issue to tell me what they thought.
Can that go in through the glove box route? If so, then it is a winner winner.
Winner winner, the Heater Treater concept with a cheaper part. That's the problem when you come up with a great idea, someone will always knock it off.
