1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
AC is kicking on when on heat
Old 12-10-2014, 03:42 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Originally Posted by ldou0110
I've tried three different Tstats and not helping
Do your t-stats have the rubber seal all the way around the edge?
  #32
Old 12-10-2014, 06:27 PM
ldou0110's Avatar
ldou0110
ldou0110 is offline
Yes the rubber ring is around the edge
  #33
Old 12-11-2014, 07:00 AM
blackex's Avatar
blackex
blackex is offline
I took my truck in to have them take a look at my cooling system before I do the blend door myself if it comes down to that being the problem. I will update when they get back to me sometime later today. I'm wondering if there could be a trapped air bubble in the coolent system causing this somehow since I just had the radiator replaced a few months back.
  #34
Old 12-11-2014, 08:45 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
If you do have to do the blend door, there is a short cut product that saves you having to take the dash out by going through the back of the glove box with a metal replacement door. Look up Heater Treater.
  #35
Old 12-11-2014, 08:47 AM
blackex's Avatar
blackex
blackex is offline
You can even save your money by purchasing a Dorman blend door replacement that has an adjustable metal sleeve for easier installation. The Dorman blend door is about $25, the heater treater is $119.
  #36
Old 12-11-2014, 10:12 AM
ldou0110's Avatar
ldou0110
ldou0110 is offline
I thought about taking mine in but hate to give up. doesn't seem like it ncan be that hard to figure out.
  #37
Old 12-11-2014, 10:22 AM
blackex's Avatar
blackex
blackex is offline
I took mine in to have a new flowmaster dual exhaust installed and figured I would have them take a look at the heat issue to tell me what they thought.
  #38
Old 12-11-2014, 11:26 AM
alwaysfords41
Can that go in through the glove box route? If so, then it is a winner winner.
  #39
Old 12-11-2014, 11:28 AM
blackex's Avatar
blackex
blackex is offline
  #40
Old 12-11-2014, 12:25 PM
alwaysfords41
Winner winner, the Heater Treater concept with a cheaper part. That's the problem when you come up with a great idea, someone will always knock it off.
  #41
Old 12-11-2014, 12:26 PM
blackex's Avatar
blackex
blackex is offline
$21 on amazon. You can send me the $90 you saved
  #42
Old 12-11-2014, 01:26 PM
alwaysfords41
I haven't saved anything, my blend doors work.
  #43
Old 12-11-2014, 01:49 PM
alloro's Avatar
alloro
alloro is offline
HT was overpriced because it used to be the only alternative to pulling out the entire dash. They might have to rethink that price now.
  #44
Old 12-11-2014, 03:25 PM
alwaysfords41
Without a doubt. Good job on Dorman's part to take advantage of it. Not good news for HT.
  #45
Old 12-12-2014, 10:24 AM
ldou0110's Avatar
ldou0110
ldou0110 is offline
good you tube I've looked at several and this is the best. I plan on doing this this week end. What did you find from the shop on your problem
Quick Reply: AC is kicking on when on heat
