Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 12-01-2014, 08:11 PM
dusterbd13 dusterbd13 is offline
dusterbd13 is starting off with a positive reputation.
need help finding a fitting
I also cant spell very good.
anyway, im working on adapting a 87ish ford 5.0 engine to a 54 ford pickup. using a Toyota 4x4 power steering box, and stock foxbody 5.0 serpentine accessories. so this means a stock power steering pump. now, I can find on the shelf hoses for the pump end all day long. unfortunately, the other end is giving me fits. so I went to the local hydraulic hose shop today to talk with them about my options. took both hose ends, and hoped to get a new piece of rubber crimped between the two.
no dice. no love. no joy.
we did find an end that mates with the Toyota box perfectly, had the right radius, etc. so that end is a win. we also figured out that we can use a JIC fitting at the other end, if I can find an adapter for the stock ford pump to AN, preferably in -6. I know such a fitting has to exist. I cannot be the only insane guy to try this. summit had no ideas. neither did jegs. googling has turned up nothing. so im begging for help.
thanks guys.
Michael
Old 12-02-2014, 08:57 AM
DR Smith's Avatar
DR Smith DR Smith is offline
DR Smith has a good reputation on FTE.DR Smith has a good reputation on FTE.DR Smith has a good reputation on FTE.
can't you cut the end off the ford hose [ that goes into the box ] and the end off the Toyota hose[ that goes into the pump ]? then connect the two with a male and female fitting ? That's what I had to do with mine .
Old 12-02-2014, 09:06 AM
51dueller's Avatar
51dueller 51dueller is online now
51dueller has a good reputation on FTE.51dueller has a good reputation on FTE.51dueller has a good reputation on FTE.
It depends on what year of pump you have. 1978-89 used a 5/16 fitting and 1990-2004 used a 16mm x 1.5 swivel fitting. I don't know what fits the older pumps.
This is for the metric fitting:
Click the image to open in full size.
Its a Russel 670530 and is available on Summits site. You will need to use the factory teflon washer though.
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
Old 12-10-2014, 11:24 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1965/77 Ford P/S pumps have a steel reservoir, the P/S pressure hose threads onto the pump.
1978: Ford changed the P/S pump on everything (except cars with Hydro-Boost & Econolines that use the Saginaw pump-resembles a 'canned ham').
This new Ford pump has a plastic reservoir, it's also smaller in diameter. The P/S pressure hose attaches to the pump w/a qwik connect fitting.
From the 1980/89 Ford truck parts catalog:
Left: Plastic reservoir pump / Right (lower): 1980/87 F100/350 & Bronco 255/302/351W P/S pump & hose installation.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old 12-10-2014, 02:28 PM
AXracer's Avatar
AXracer AXracer is online now
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
Toyota PS box uses 2 different sized fittings: High pressure hose fitting is 16mm inverted flare same as many OEM PS pumps and boxes. Low pressure return hose to box fitting is non standard 17mm inverted flare that originally had a short length of steel tubing in it. This fitting is difficult to find, is not sold separately, Toyota doesn't sell it. If you did not get the fitting with your box, Mid Fifty sells a Toyota hose kit that includes a 17mm adapter fitting. Gotta Show sells a braided stainless hose kit that contains their own manufactured 16mm and 17mm stainless low profile banjo fittings that are great if you have hose to header clearance/heat issues. The box end of the return hose, being low pressure, just pushes over the tube at the box fitting and is clamped with a simple hose clamp, no special hose needed.
Where in NC are you?
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Similar Threads
Toyota MANUAL Steering Box Pitman Arm Issue okedokeno 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 10-26-2012 11:45 PM
toyota steering hose MCarlson 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-23-2012 01:39 PM
1963 F-100 2WD Power Steering Swap 460na63 1961 - 1966 F-100 & Larger F-Series Trucks 1 06-27-2012 09:44 PM
Using a Toyota Power Steering Box in manual mode teardropty 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 04-06-2012 02:55 AM
Toyota Box Pitman Arm Source - For Sure This Time! BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 05-15-2010 05:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
