2002 F-350 Altitude Adjustment
Ken's shop is a wood shop as well, hence "woodnthings". I believe that central shop vac with an outlet to every power tool keeps the dust way down. You can see the big white pipe for the vac conduit in the background of one of his shop pictures. He even has one pipe to the ground with a scoop opening - this is used with a valve and he sweeps the floor into the vacuum. No picking up and dumping - really cool.
Thanks! The only special tool was the pitman arm puller. It's not even a special tool IMO. They are available for under $30 and can be rented at most auto parts stores for free. You will need some bigger wrenches for the pitman arm nut.
I did "document" the whole process with pictures, so I will put together a "how to" to share. As many people who have done lifts know, the instructions are pretty basic with no extra details. Anyone with a good mechanical aptitude can do this.
Wider tires with more contact can be helpful in the snow. The more surface area you have, the better you are to spread the weight out. Tread pattern seems to be the best deal for snow/mud. That helps with traction on it. So far there isn't much good for ice and an 8500# truck trying to stop!
#29
Yeah... we just had an ice storm warning. My master plan was to stick with the Prius because FWD is better than RWD or 4WD - but AWD is about the best on ice (I don't have a vehicle with that). Without studded tires, I figured it would be less of a mess on some of the hills around here (inertia can be a bugger). Of course... there's always the aspect of being in a tank (Superduty) and protected from those less experienced with ice driving.
