LED's in place of stock fogs? (2005+)
Anyone run LED driving/offroad lights in place of the factory fogs? I can run a 20" bar, but I like the looks of two cubes to keep the factory look.
I found these but know nothing about them. I'd want the brightest cubes I could find...
2005-2015 Ford F250-F350 Fog Light Replacement Kit - Fire Wire LEDs
I could also run these from Rigid... http://www.socalsupertrucks.com/1999...t---rigid.aspx
The throw is (* subjectively * ) a bit wider and farther. The 5000K color temp helps make the throw more visible then the stock yellow-ish halogen were. I can try to take a pic tonight if it helps. I know that with parking lights only and fogs I can comfortably drive on side streets with plenty of visibility albeit it much lower and shallower then the normal low beams....
I replaced the low/high to 5000K bixenons also. Really made a huge difference in visibility. They are aimed well and haven't had anyone flash their brights at me from glare yet.
I don't plan to run them while having traffic come at me, this would more be used like off-road lights to illuminate more than the highbeams on dark country roads or off-road.
I'd like to run a set of Baja deseigns squadrons, but I'll need to fab up some kind of brackets. Rigid makes brackets, but I think the mounts are way different from a dually to the Baja.
Squadron XL Pro LED Lights
cockeyed00
1999 to 2016 Super Duty
10-21-2003 12:14 PM
