1978 - 1996 Big Bronco
85 bronco fuel issues
Old 12-01-2014, 07:29 AM
rollman's Avatar
rollman
rollman is offline
I was driving down the road and got cut off and sent into the snow drift jumped into the gas and got out I made it about ten feet and died after checking it out I am not getting fuel . I replaced the pump and still no fuel
Old 12-01-2014, 03:28 PM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
Does your truck have a fuel pump safety shut off?
Old 12-01-2014, 07:13 PM
rollman's Avatar
rollman
rollman is offline
its carburetor truck so I have no idea if it has a fuel shut off or not
Old 12-02-2014, 04:17 AM
gatorfor88's Avatar
gatorfor88
No it doesnt unless it has electric fuel pump.
Old 12-02-2014, 08:58 AM
rollman's Avatar
rollman
rollman is offline
that's what I figured because it was carburetor it didn't have a fuel shut off I am stumped I can't figure out what is going onI can get it to run fine on a prime but it will not pick up any fuel out of my tank
Old 12-02-2014, 11:24 PM
Torky2's Avatar
Torky2
Torky2 is offline
Well, I would replace the fuel filter first, cuz their cheap and easy, and then you'll know it's clean. If that has no effect, I'd grab a length of rubber fuel line, like 6-10 feet long, and connect it to the fuel pump inlet instead of the rubber hose that connects steel line to the pump inlet. And try starting it out of a gas can with known good gas. May take a bit of cranking to get fuel all the way up to the carb.
If it runs fine out of the can, then you know where to start looking:
-cracked rubber fuel line on pump inlet letting in air, or
-leaky or plugged steel line from back to front
-rubber line from tank to steel line
-tank pickup line cracked/broken either on outside of tank, or inside tank
-tank pickup sock filter plugged
-tank smashed, etc
Really, if it runs fine out of a gas can, I'd give it a real close visual first from front to back, may find something broken/bent closed/disconnected, etc. considering what happened.
If not, you could hook up the pump again to the steel line, and move the temporary gas can setup to the back end of the steel tubing near the gas tank, and try running it again. Need to run long enough to use up all gas in carb bowl (so ya don't think it's fine, when it's really not, just running on what's left in the bowl, if that makes sense).
It doesn't take much of an air leak under fuel pump vacuum to pull in air instead of fuel.
Texican01
6.7L Power Stroke Diesel
02-20-2017 10:40 AM
chicagodragon
12-23-2009 07:16 PM
rondawgg1118
02-11-2007 09:30 PM
shawn
01-15-2004 12:34 AM
Quick Reply: 85 bronco fuel issues
