Good evening, and good morning PA! It's going to be a quick day for me, ended up picking up the night shift for the next couple days, so I'll be on the threads much later than usual
Hey Pat, how hard do you think it would be to remove that bracket from the column? I was thinking of just using the bracket that comes with the 64, which wraps around the column. If I was going to do that, The 67 bracket has to come off. I'm thinking I can just drill out the welds.
Yeah, shouldn't be too tough. Is it spot welded? You can actually buy a spot weld bit from Eastwood, I have a couple of them, since I've drilled out a couple hundred spot welds. Or, you might be able to cut it off.
