got a little over 2 barrells of oil from the fair!
Used the last of that oil awhile ago. got three batches of fuel. Higher gel point for some reason, the beast gelled up when it got down below zero. I'm now out of oil, but it's too dang cold out anyway. I'll start going after it again this spring I think!
I lose about a mpg or so when I run straight bio. probably around 17.5 or so on the hwy. Lose a little power too, but only notice it towing the boat in the hills. At about 1.20 a gallon i don't complain though.
I meant your bio production set up. I was looking into some different setups, something easy to set up and take down every couple of years when I move. I eventually want to run bio, but don't have anywhere to buy it locally that I know of, or to make it myself as of yet.
I saw your setup, quite impressive. I plan on doing some heavy modding in the spring when the weather breaks. Starting with an engine refresh to support the added goodies I have planned.
Sorry, I meant to say one thing, but my hands wrote the abridged version.
Think mine wouldn't be move friendly. 50 gallon water heater and pump, along with several 55 gallon barrels and pipe.
Thanks!
Curt
I'll have to look into that. Also, do you make soap with your glycerin? I was reading up on it, and good homemade soaps sell for quite a bit, that and the lye cuts grease/oils better than orange and other compounds. It's a great way to keep the cycle of reusable materials going.
