54 ignition problem
54 ignition problem
Hey guys need some help. I have an ignition switch on my 54 ford truck that has 3 terminals marked ign, acc, and batt. Which terminal on the switch do I use to go straight to the coil. Since I didn't have one labeled coil I wasn't for sure if I hooked it to the battery or accessories terminal on the ign switch. Thanks
tractormanbill
07-13-2014 11:15 AM
