97 f150 4.6 sohc to 4.6 dohc swap need help
i have a 97 f150 4x4 that i am doing a swap on. the dohc motor came out of a 98 Lincoln viii.
do i need to use my wiring harness on my f150 or the lincolns? i have the new engines wiring harness and computer etc.
if i used the new engines computer and harness would i still have to delete the imrc?
this is my first major swap i need all the advice you have on what i need to swap arounnd on the truck.
if any one has done this swap please help me thanks
I'm far from an expert on this topic but will tell you I assisted my neighbor on an engine swap he did on an older Explorer. Long story short, it was a nightmare and took quite a while to get the technical help he needed to get the thing running right. He ended up replacing the cluster, computer, and two other harnesses behind the dash from a donor vehicle that all matched.
I'm not sure if you'll have a similar issue but if you have an electrical background it will definately be a good thing.
