Electrical problem
Electrical problem
Just fixed one thing, immediately have another problem ..... Anyways switched out a blower motor resistor, and it works fine. Problem now, truck won't start. It will crank, but I have no fuel pressure. Checked all the fuses, replaced one instrumentation fuse, no luck. Anyways another oddity I tried to check voltage at back of my fuses for 12 volt power, NONE of them have it. Is this odd, with key on ? When I put key in accessory position, nothing happens. So, wondering if I might have a Ignition switch problem ? Also I have a battery voltage meter on the dash, it is indicating only about 8 to 10 amps with key on before cranking, I usually don't look at it if truck cranks and runs, so not sure what is normal .....
Suggestions ??
Suggestions ??
Nobody has an opinion on the whole scenario as described ?
Inaccurate gauge, poor ground at G200 (behind passenger side kick panel), or poor power connection to the cluster. More than once I have found one of the connectors behind the cluster unlatched and slowly falling out of the socket.
Curtis_v
16
08-06-2017 02:25 PM
sabresfan616
08-20-2012 06:41 AM
