1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Please Help. Oil in spark plug tube and Ticking Sound.
Old 11-30-2014, 12:06 AM
Nuneszachary87's Avatar
Nuneszachary87
Nuneszachary87 is offline
Hi, I am new here, and hope your community could pease be of help.
I have a 2001 Lincoln Navigator with a 5.4 Intech Engine. A ticking sound developed, and after my neighbor, (who told me about this community), removed the spark plugs, their was oil found in in the number 3 spark plug tube, with a little in number one as well. Will replacing the spark plug tube seals and valve gasket solve these problems? Will we need anything more? We would be most appreciative for any help. Thank-You. .
Old 11-30-2014, 10:15 AM
UtilityCow's Avatar
UtilityCow
UtilityCow is offline
Seems like leaky valve cover gasket. Spark plugs, boots, valve cover gaskets should handle it, however I've never donet his job on a DOHC. The ticking is from that coil? It's probably shorting through the oil instead of the plug tip. Following path of least resistance. BTW, get Motorcraft parts where possible.
Old 11-30-2014, 10:50 AM
alloro's Avatar
alloro
alloro is online now
Received 4,194 Likes on 2,430 Posts
Is the tick coming from the oil soaked spark plug area or does it sound like a ticking valve?
Old 11-30-2014, 03:45 PM
Nuneszachary87
Thank-you, yes. Not sure what the procedure is to take off the valve cover to get to the gaskets. We have got to the plugs thought, and we are going to test the coils for nominal output. Also do the spark plugs need to be removed in order to replace the spark plug tube seals?
Old 11-30-2014, 03:47 PM
Nuneszachary87
Not sure how to tell that, except we will test the coils packs for operation.
Old 12-01-2014, 09:17 AM
alloro's Avatar
alloro
Use a piece of hose about 3' long. Block one ear and hold one end of the hose to your other ear, then use the other end of the hose to probe around listening for the tick through the hose. Obviously watch out for moving parts and the serpentine belt.
Old 12-01-2014, 11:17 AM
r2millers's Avatar
r2millers
r2millers is offline
Are you sure it's oil and not antifreeze as this is very common? To your point, the intake manifold gasket can start leaking and allow antifreeze to fill the plug tube.
I've used dielectric grease around the COP and it will run without issue for many months/years if you don't want to remove the manifold and repair.
Not the best way but still a band aid.
lovesaved7
Large Truck
20
12-29-2018 11:07 PM
Carlos Hernandez
08-12-2018 07:50 PM
jdpoissa
03-22-2015 07:48 AM
Mochajones
10-31-2006 11:47 AM
SkynyrdFreak
Garage & Workshop
01-16-2003 04:28 PM
Quick Reply: Please Help. Oil in spark plug tube and Ticking Sound.
