late 04 no start Please Help!
Late 04 6.0 I have Literally replaced all the high pressure oil system parts with the exception of the branch tubes. Ive replaced hpop, I have old styel pump therefore i replaced the j-tube on the pump, ipr, icp, stand pipes, dummy plugs, nipple cup orings, injector seals and orings. started out originally a no start diagnosed it to bad hpop so thats when i replaced the pump and the ipr it then started like a brand new truck everyday but had a hot no start. so i replaced all the other parts... still start like a brand new truck but had a hot no start. i noticed when hot koeo ipr would be 14.7% but once started cranking went straight to 85% so i thought maybe i have a failed ipr. I went and bought a new ipr and all parts replaced are oem parts. I started the truck idling great for about 20 minutes drove it down the road to get it opened up and warmed up real good never even got to open her up about 3 miles from my house truck dies. i had to get pulled back home... i pulled the icp pigtail still would not start but it is brand new icp sensor. koeo ipr 14.7% crank immediatly goes to 85% hpop only goes little over 200 psi.. ive got the ipr air test line that goes straight into the ipr port and have done an air test no air or gurgling from the oil filter housing. but i have a strong his and feel air on the passenger side oil rail near the back#7 injector. injector. The injector seals still look good so i dont think it is the injector. I'm curious is there a way to tell if i may have a hole or bad branch tube? im considering pulling my oil rails and swapping side with the rails and doing an air test again and see what happens... Also, considered pulling the turbo and hpo pump cover and running air again see if there is a leak still at the j-tube.. I dont know were else to look or go im stumped on this one.. Please help!! Thank You!
I would remove the turbo and oil filter and air test it again and listen for air in the turbo oil return port in the HPOP cover and the other usual places, When you say the injector orings look good did you mean the top injector orings too? The ones that seal to the nipple cups? Have you read through this thread? https://www.ford-trucks.com/forums/1...ole-story.html
I've read this and you're other post. Sadly, I don't think you have a choice but to pull the turbo and hpop cover and run another air test.
New 03 and 04 hpop can be bad. Moreso if they are rebuilt.
I don't know how to check for a leak in the branch tubes.
Recheck the oring at the ball tube on the injector where you hear the air.
Check out these videos, its the same engine build as yours.
Ford 6.0 Powerstroke High Pressure Oil System Air Test - YouTube
Found source of HPO System Leak - 2004 Ford F250 6.0 Powerstroke - YouTube
Ford F250 6.0 Powerstroke Successful High Pressure System Air Test - YouTube
I mean no! dis-respect sir! so Pleas don't take offense but, these videos are all common knowledge. I do appreciate the thought though! I've done this and even pulled the pump again today and inspected the top and bottom orings both are good condition. I didn't get chance to do an air test with the pump cover off but plan on doing so tomorrow.. my one question or curiousity is the j-tube even he says in video not sure if that is suppose to wiggle as it does. Ive been given conflicting stories some say yes that's common some say no its not suppose to be like that.. so which one is it...
None taken, the point of the videos was to show what he found and what a successful air test should sound like.
I understand that's why I am stumped on why im still having a leak.. only thing I know to do is air test it with the pump cover off and as suggested pull the nipple cup off the rail and inspect it also..
Disconnect the j-tube from the quick release going into the branch tube. Get a rubber tipped air nozzle, and apply pressurized air directly into the branch tube. At this point is where you will know if you need to go left or right (or not at all). By doing this, you are taking the HPOP and j-tube out of your air test equation.
I will definatly give that a try thank you!
