Metal rain guards possible to replace?
Ok, I will admit to being a bit OCD when it comes to symmetry. So my '89 is missing the rain guard over the window. Can only assume this was taken off and not replaced as the door was definitely re-painted. Are these removable? Can they be purchased after market to be replace? I know the plastic ones just use an adhesive but the one on the passenger side looks like its actually part of the door or is between the door and the seal. Any help would be appreciated.
on
those are aftermarket.i have a set on chip truck.they are stainless steel and they are held on via small Philips head screws like 87-xl stated.
you can remove it if you want,or you can buy another set.
auto ventshade 12068
Received 3,107 Likes
on
Thanks for the responses guys. I actually like these better than the plastic ones (and until I replace the passenger window motor its keeping the rain out from the window not staying up all the way. I've shimmed it up with some cardboard for now, but want to get the motor soon.
Speaking of rain, do any of you know where the most likely spot under the cowl or behind the dash/firewall that may leak when it rains? Its not major, but when its a really heavy rain, I'm getting some drops on the driver side by the parking brake.
on
These little jewels affectionately known as a cow pu**y will become clogged with debris over the years. I think they can be accessed by removing the inner fender splash shield, cleaned up and reinstalled. If your cowl fills up during your windshield seal test then these are the issue. There's one on each side.
Cow poontang 1
Cow poontang 2
Cow poontang 1
Cow poontang 2
bout-time
07-24-2013 05:10 PM
hotrodbob51
08-25-2012 11:47 PM
r2000f150
07-05-2010 05:10 PM
pipman76
12-20-2008 09:16 PM
