2004 F-250 6.0
#61
Just wanted to put it out there. Thank you so much for offering to do this for me Shane. I ended up deciding to rent a vehicle to get us home to our secondary vehicle. I left my baby at a diesel mechanic who is highly recommended by many people in the town we were in and ordered the same kits. I had them sent directly to his shop. He diagnosed my issue the same. HPOS leaking from 7 injectors. I had to get back to my construction company and get my daughter back in school. I wish there were more people like you in the world.
You are very welcome! Folks here have saved my bacon many times. I just wish I had the troubleshooting experience to contribute more...
My kit came with the nipple cup o-rings. It is my understanding that the upper injector o-ring gets worn due to HPO leaking past the nipple cup. I would change them if it were me. You do need the tool to remove them. PM RobinThahood aka Mark, he makes and sells them.
#64
"The nipple cup tool"
That made me feel good.
#65
#66
In progress...
Injector o-rings are in the mail to Arkansas. After that I'm sure I'll have to deal with the battery light/charging issue. I had planned on changing the main wiring harness anyway as, it's not, if it will go bad/melt/burn up/crack, it's when it will. Also like said before most likely going to put a new alternator on her also. Once I have her home I will check/clean/replace all grounds and physical connections (necessary).
I hope after all of this I will get at least 50,000 miles out of my sweet blue bitch.
So on another note... To chip or not to chip? I've heard and read after an EGR delete you pretty much have to? True or not true? I drove 574 miles on 24 gallons of fuel. That's pretty much 24 MPG. Can I really do any better with it chipped...
I can hear ya'll now... GET IT FIXED FIRST! I know, I know, but I love that hateful beast. I want what's best for her AND I.
Oh yeah... My letter to Crain Ford in Little Rock is in progress
Thanks.
Thanks.
#67
Perfect
Awesome. That's what I was hoping. I asked the mechanic to be honest about a visual inspection of EACH nipple cup. If they are visually worn from the HPOS leak I will replace them. This, however will cause
#68
From those that should know (I am not chipped), a program will not improve mileage enough to justify the cost. Certainly not better than 24 mpg.
Most chose to keep it stock if they don't have head studs. However there are tunes that are supposed to be oem head bolt safe. SCT seems to be the tunes that most choose to run.
#69
#70
I was informed by Brian at Bostech the ISK102 does not come with the nipple cup o ring.
Hope that helps.
__________________
Xtreme Diesel Performance | XDP
Call us @ 1-888-DIESEL4
#71
#72
#73
Awesome.
I believe this is what you are looking for.
High-Pressure Oil Rail Seal Kit - Riffraff Diesel Performance
Ordered and sent to the shop. Thanks brothers.
#74
#75
