94' F-250 Are there any 460 gods out there
Old 11-28-2014, 12:38 PM
r9wolves's Avatar
r9wolves
r9wolves is offline
Unhappy 94' F-250 Are there any 460 gods out there
Ran Great
Senario-died ,would start & run 30mins +/- then die, then restart and die.
Replaced; fuel filter then throttle position sensor,.. module,...distributor,....then coil! Now won't even start no spark. please any suggestions, ideas
Thx, Sue
Old 11-28-2014, 02:24 PM
critterf1's Avatar
critterf1
critterf1 is offline
Have you checked the basics or are you just throwing parts at it?
Old 11-28-2014, 03:06 PM
r9wolves's Avatar
r9wolves
r9wolves is offline
started with fuel filter, checked pressure at rail, then was checked with reader and was told replace TPS and module still would start and run a bit, replaced distributor still same then tested coil was 1.3 so replaced that then nothing, no spark
Old 12-02-2014, 10:16 AM
subford's Avatar
subford
subford is offline
Remove the SPOUT shorting bar and see if spark returns.
Desireg
09-25-2015 05:22 PM
guy9924
10-26-2011 09:49 PM
ned.funnell
07-15-2011 04:02 PM
duck94
23
03-24-2011 09:35 AM
pintoches
12-24-2010 10:02 PM
Quick Reply: 94' F-250 Are there any 460 gods out there
